[quote author="idylldon"][quote author="CJ"]I found this, how do you hook up the gate?
"Noise gating (which is just what it sounds like. A noise gate placed after a reverb device gets you that Hollies' "Long Cool Woman" vocal sound, or the ubiquitous Phil Collins "In The Air Tonight" drum sound). "
link[/quote]
I believe you just put the gate after the reverb and adjust it to cut off as much of the reverb tail as you find aesthetically pleasing. On snares, it seems to give the sound a bit more bite as the gate chops off the decay abruptly, which seems to add to the definition by temporarily adding some "space" in the mix.
Don[/quote]
Another way that a noise gate could be applied to improve a spring reverb's sound is perhaps use a very slow attack to cut off some of the leading reverb swell. One common problem with springs is that the first repeat occurs after only 25-35 mSec from the transient attack. Repeats after that are spaced 2x that or 50-70 mSec apart (time to transit back to the driver end, reflect, then transit to the receiver end again). In studios a common trick was to use a little pre-delay (maybe 50 mSec) on the reverb send to improve the sound.
link[/quote]
Don[/quote]
