mikep
can someone point me to a refrence or give an opinion of the practical way to do this?
the way I do it is to pick the R based on the current for an accecptable amount of voltage drop, then 1/2piRC to find the corner freq. with regulated supplies you obviously don't need to shoot for .1 Hz, but Im not really sure how low is necesary in general.
additionally, two issues can crop up.
1) If you are decoupling an output stage and have limited voltage at the rail to start with, the desired voltage drop might be "zero". I tend to go for half a volt, but I picked that number out of the air.
2) If you are trying to minimize supply current variations all the way down to low frequencies with low resistances in series, this leads to 1000000000000uF capacitors. does anyone know of a tricky way to bootstrap this C without negating the current-smoothing effect?
I know, it is a comprimise that varies from case to case. I just wondered what the "guidelines" are for this kind of thing.
mike p
mike p
