frazzman
Re: 3D "AIR" EQ - "Night EQ" PCB's Complete!
« Reply #1060 on: January 31, 2014, 08:49:05 AM »
You already excluded a broken right side XLR input or output connection ?
With input signal present, compare right side with left side channel to see where signal get lost might be the easiest approach, following from input to output, IE compare AC voltages at U4-pin1,...., U5-pin6, U4-pin7.
Yeah checked the XLR wiring, those molex crimp pins have sent me on a wild goose chase before. I'll follow your lead and see where I get. It's strange as you can hear the eq working even though it's barely audible. I'm cross eyed from putting all these trimmers in, we will see what the new day brings. Thanks again
Autophase
« Reply #1061 on: February 02, 2014, 10:40:49 AM »
Unfortunately I don't have the time to finish my Nite EQ, if anyone is after a pair of stereo boards I've got a post in the Black Market
http://groupdiy.com/index.php?topic=55086.0
frazzman
« Reply #1062 on: February 03, 2014, 01:08:06 AM »
Hi Harpo,
I've followed your recommendation, with a 1khz sine WAVE. I found a few deviations between the working and non working channels.
U5 - Pin 6 on working channel measures 0.868VAC. On the non working channel I have a negligible AC reading here.
Pin 7 on U6 is showing 0VAC on the non working channel.
On working channel this measures at +1.732VAC for the given input signal, which is the same reading when measuring at the output XLR pins.
Bear in mind this channel use to work fine, the issue has only arisen in the process of swapping out a heap of resistors with trimmers (R21,R23,R18,R20,R15,R17,R12,R14,R9 & R45,R43,R41,R39,R37).
I've already removed all of the IC's and checked that the trimmers are at their correct calculated resistance and they all checked out OK
No doubt I have introduced a fault during this process as the left channel is working fine with the same configuration. I am just having trouble finding where...
Thanks a lot
« Last Edit: February 03, 2014, 01:15:55 AM by frazzman »
Harpo
« Reply #1063 on: February 03, 2014, 05:17:09 AM »
So either the opamp is broken or signal doesn't arrive at its non-inverting input (this is a virtual ground node, so current not voltage).
L/R voltages are the same at U4-pin1 (output of input debalancing stage) ?
L/R voltages are the same at U2-pin1 (output of 640Hz gain stage) ?
Does last measurement voltage or slightly lower arrive at the non working channel U5-pin2 with the U5 opamp out of its socket (broken trace check) ?
U4-pin7 on working channel (unsigned)1.732VAC with jumper set for unbalanced out config. On non working channel this is only a followup from U5-pin6 (inverting 2* nothing is still nothing).
A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools.  -Douglas Adams
Harpo
« Reply #1064 on: February 05, 2014, 06:20:27 AM »
Quote from: Bonsaimaster
Ok here is what I got. As I plug the module in my rack the power LED lights up and the Peak LED lights up. No signal passes thru. When I hook it up with my Classic API extension card non of the LED's light up. Voltage checks are all over with U1 and U4 showing varying voltages. TP4 TP5 show about .1mV.Any thoughts?
Thanks in advance
Bonsaimaster
Took me a while to figure out what project your PM might be related to.
Did you place the 4 jumpers at the J9 connector, IE 'Link 1&3, 2&4, 7&9, 8&10 for Rear panel I/O', as explained at the left side of 'Prodigy Nite500 EQ schematic.pdf', so your input signal across XLR-pins2/3 arrives at TP4/TP5 ?
« Last Edit: February 05, 2014, 06:23:37 AM by Harpo »
frazzman
« Reply #1065 on: February 10, 2014, 09:56:23 PM »
Hi Harpo, and anyone else still interested in this thread...
So this is how I finished up with my unit. (I did find a dry joint on my right channel which was causing a loss of signal).
With 14 trimmers fitted on each channel to compensate for parts tolerances, my frequency response is better, but I think its as close as its going to get.
So far, i'd say that EQ sounds "good", not excellent but I am thinking this is due to some dips in low end frequencies. Attached is how my frequency response ended up.
I feel that the signal through the EQ (all pots centered) kind of sounds like its loosing a bit of 'balls' (subjective term... maybe = loss of some low end??
Drum sample: No EQ - https://dl.dropboxusercontent.com/u/108741277/niteeq/drumloop-noEQ.mp3
Drum sample: Nite EQ (all pots centered) - https://dl.dropboxusercontent.com/u/108741277/niteeq/drumloop-niteEQ.mp3
It becomes a bit of an interesting exercise - am I percieving some low end loss because I can see it on a graph, or can actually hear it? I *think* my -0.35db~ dip @ 350hz-ish is this perceived loss of low end (or "balls")
There is a pretty small volume drop with the EQ engaged due to tweaks of feedback resistor...
The EQ sounds pretty nice if you disregard any empirical info/precision and just crank the knobs until it sounds good, more like an effect in a way, and probably the way this was designed to be used...
Interested to hear any thoughts?
dmnieto
« Reply #1066 on: February 10, 2014, 11:08:09 PM »
No, i can hear it too, but it might be more related with the fact that the tracks are massively in anti-phase... Just mono it and you will see.
In any case, hearing it only one channel at a time, it does not seem like it has lost punch for me... It is a tad brighter though.
frazzman
« Reply #1067 on: February 10, 2014, 11:48:13 PM »
Hey there, thanks for the feedback... I didn't check that actually. When you say anti phase ... You mean the eq-d track L and R channels are out of phase with each other ? I wonder what could cause that... Xlr wiring pins reversed ?
I'll have another listen... The slight brightness/boost +0.5db~ in the highs could be attributed by the wide high end freq boost
frazzman
« Reply #1068 on: February 10, 2014, 11:52:11 PM »
EDIT: Looking at the waveforms I can see exactly what you mean, completely out of phase...
dmnieto
« Reply #1069 on: February 11, 2014, 12:39:20 AM »
I'd say that you have the hot an cold pins in one of the channels reversed, or some kind of wiring issue. It was quite fenomenal on a first listen because it felt like the sound was bouncing from one side to another in my room when i moved the head a little bit.
But yeah, I did feel a slight less punch and detail in the sound, it could be because the original was a bit louder and that somehow the mp3 compression added more artifacts. It is also that the 350Hz is right in the middle of where the fundamentals of the kit/snare are so the 0.5dB difference can actually be heard. Dunno.
Do you mind printing the wav files and inverting the phase of one of the channels?
frazzman
« Reply #1070 on: February 11, 2014, 02:14:36 AM »
Hey dmnieto,
You're a legend ! I can now see I have reversed the hot and cold pins on the left channel XLR in. What an idiot I am!!! Because these boards are self etched , there's no silk screen so I stupidly wired the input wrong on this channel! I'm pretty certain it will work properly now. The dip at 350hz is only about -0.3, it's wide as well so I don't think it should be too catastrophic...
But having the polarity totally flipped on one channel is diabolical!
I really was scratching my head wondering why it sounded so "odd", interestingly as you tweak some of the knobs, it kind of started to sound better (phase shift due to boosting certain bands..?)
Anyhow I'll report back soon once I've fixed it. Such a simple oversight that I embarrassingly have probably spent hours working on - I'm glad I posted the sound clips and that you took the time to listen to them. Thanks again...
dmnieto
« Reply #1071 on: February 11, 2014, 02:53:07 AM »
You are not an idiot, I made the same mistake on one of my 1176. I chased that one for a full weekend. In my case it manifested as oscillation at low levels... This was due because I was measuring on a single ended equipment and reversing the phase was actually creating a positive feedback instability when I was using the passive attenuator so the signal was very close to ground.
On the other hand, it was a cool LFO.
frazzman
« Reply #1072 on: February 11, 2014, 04:20:18 AM »
This is perfect .... All fixed! Such a minor oversight with major implications. The sound was so strange before, it makes perfect sense now ... And more importantly it sounds awesome, the way I thought it always should have sounded.
I'm glad you found your bug on your 1176 build. I loved building my 1176s , the last one worked perfectly on first power up... As opposed to this build, I would hate to see how many hours I spent tweaking this unit and chasing this bizarre issue. I'll be happy never taking the lid off this thing again
Jordan
« Reply #1073 on: August 15, 2014, 05:42:25 AM »
Salut,
Je dĂ©couvre cet EQ aujourd'hui. Peut ĂȘtre un peu tard ... Est il possible d'acheter les PCB? Merci pour votre aide !
Amicalement. ;)
Jordan
steves.mastering
« Reply #1074 on: October 28, 2014, 11:40:55 AM »
Is anyone still making these PCBs? or does anyone have the etch files so i can make myself some? :)
thank you very much
Ste
snaper
« Reply #1075 on: March 04, 2015, 03:25:31 AM »
thank you very much
Ste
Interested in etch layout too :D
Whoops
« Last Edit: March 05, 2015, 02:17:08 PM by Whoops »
peterc
« Reply #1077 on: March 05, 2015, 01:37:04 AM »
Hi Whoops
PM sent regarding these files.
Peter
If opportunity doesn't knock, build a door.
Whoops
« Reply #1078 on: March 05, 2015, 02:18:06 PM »
Hi Whoops
Peter
Links removed
mrscary
« Reply #1079 on: March 18, 2015, 12:17:47 PM »
Does anybody still have PCBs available for this, or perhaps the etching files so I can make my own?
Last post December 18, 2019, 11:49:49 AM
by manulaudic
Last post August 25, 2009, 07:06:28 PM
by nhaudio
Last post October 23, 2009, 07:53:29 AM
by ytsestef
Last post December 13, 2010, 05:36:54 PM
by pucho812
