weiss
Re: 3D "AIR" EQ - "Night EQ" PCB's Complete!
« Reply #1200 on: February 11, 2019, 10:02:01 AM »
HI Weiss,
LM317 and LM337 are adjustable voltage regulators.
Check their datasheet on how to install a trimpot
check also the implementation of these regulator in the JLM PSU:
http://www.jlmaudio.com/ACDCVer2sch.pdf
I think in mine I just replaced R1 and R5 for a 5K Multiturn Trimpot
thank you!
jrasia
« Reply #1201 on: April 15, 2019, 07:06:48 PM »
I'm using a DIY Racked PCB of this EQ, and have a particular question about 60hz hum I'm getting.
Ch1 is very quiet.
Ch2 is fine so long as I have the 'Air' switch on.  When its in 'Off' position, I'm getting the 60hz noise.
I have Mumetal around the transformer, tried rotating it with no change.  Audio cabling is all shielded.  All wiring is nicely twisted and moved away as far as possible from the psu.
Any ideas?
« Last Edit: April 15, 2019, 08:06:47 PM by jrasia »
lukas
« Reply #1202 on: April 16, 2019, 04:55:47 AM »
Yeah...bad power supply.
Harpo
« Reply #1203 on: April 16, 2019, 07:06:08 AM »
assume your schematic and pcb to differ from this topics schematic and pcb.
So this seems pre psu related. (Post psu would be dominant 120Hz from rectification).
Double check traceside of pcb. There might be a wire not clipped off that now connects to your case ground.
Other possibility might be a device inducing mains frequency into your eq with lid open. (halogen spot, ...)
Good luck
A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools.  -Douglas Adams
jrasia
« Reply #1204 on: April 16, 2019, 08:32:00 PM »
Thanks guys!  I'll have to measure what frequency I'm getting,  but it may indeed be 120hz.
Olegarich
« Reply #1205 on: June 24, 2019, 03:36:46 PM »
Hey guys, could you give me a link to working schematics?
weiss
« Reply #1206 on: June 24, 2019, 05:30:20 PM »
here you go  :)
Olegarich
« Reply #1207 on: June 25, 2019, 02:25:38 AM »
Thank You Man!!!!
manulaudic
« Reply #1208 on: December 18, 2019, 11:59:38 AM »
Hi, i wanted to build thi project from Diy racked but i can see he stole the project somehow? could i purchase the pcb from the right owner? or could i etch my own?
I'd greatly appreciate it, this would be a super nice project :)
Manu
Whoops
« Reply #1209 on: December 18, 2019, 01:35:55 PM »
Manu
I still have some pare boards for this project that I will never use, I can sell them.
PM me
manulaudic
« Reply #1210 on: December 18, 2019, 02:55:08 PM »
PM me
I just sent you email :)
Manu
3nity
« Reply #1211 on: January 02, 2020, 04:58:50 PM »
Hey guys.
Can anyone help adjust the level difference when eq in and bypass?
Life is a path, death the destination.
Whoops
« Reply #1212 on: January 02, 2020, 09:43:15 PM »
Hey guys.
Hi 3nity,
there's a document for it, it was posted on this thread and I re-posted it again some pages back.
what pots did you use?
3nity
« Reply #1213 on: January 03, 2020, 10:03:45 AM »
Hi whoops.
I used the 500k from small bear.
I switched r48 from 52.2k to 8.2k and levels are almost identical.
However i lost some low end here.
Ill look for your post.
Whoops
« Reply #1214 on: January 03, 2020, 08:59:08 PM »
Hi whoops.
I don't think you will ever be able to get the same level with EQ in and in bypass with pots without a center ident/detent.
You need to know the center value of the pot and use the excel document to adjust the resistors for each individual pot.
With those pots without center detent the center position will never be same, so the center value will never be same.
You should get the Pots with center detent from Audiomaintenance
shot
« Reply #1215 on: January 04, 2020, 10:34:02 AM »
What would be the best solution to adding output level potentiomenter only for EQed signal? I'm not looking for adding gain with that pot but just some attenuation before signal leaves the unit in order to enter next unit in chain with the aprox. same level as was the flat/bypassed signal.
I guess I could put a potentiometer instead of R30 to vary the NFB on U5 opamp but that would affect the bypassed signal also. And I want to have bypass signal intact.
Would a simple voltage divider be enough in the entry of EQ SUM signal to the switch SW7? Or would I need to do it with variable gain opamp at that spot? Or maybe my thinking is wrong and I should do it elsewhere?
Luka
Harpo
« Reply #1216 on: January 07, 2020, 05:13:13 AM »
Yupp. For a FI +/-6dB varying level adjust you need a resistor varying from roundabout 28K up to 112K, so lift one side of R30 in order to build a series string of the required fixed and variable part values, place a 2nd 56k in parallel to the already existing R30, giving 28K for the -6dB min.gain setting, lifted side of this now 28K paralleled resistor connects the ccw end of a 100K pot with 560K in parallel between ccw end and wiper, giving 84K85, pot wiper joined with pots cw end connects to the lifted end of R30 on pcb.
No. This spot is a current node (virtual ground), not a voltage node.
Is one possible solution (built like U5 with same Rfb value as R48, probably 56K, switch now selecting between now variable U5 out or the bypass substitute fixed gain opamp output, switch pole further leading to R27 and C15).
Another (maybe prefered) option could be a hardwire bypass between device input and output.
good luck
shot
« Reply #1217 on: January 07, 2020, 06:42:45 PM »
Harpo you are fantastic! Super precise answer. No additional questions needed.
Thank you for your effort!
Yes, I also started thinking in that direction. I would just abandon internal bypass solution and add relay for true bypass.
Luka
Rockitdog
« Reply #1218 on: February 11, 2020, 07:58:55 AM »
Hi Guys
Does Anyone have a link to the self etch and layout files?  I've got the schematic, thanks Weiss, but need the other files.
 All links seem to be dead.   :-\
« Reply #1219 on: February 11, 2020, 08:02:39 AM »
Here's everyting I have on this project : https://we.tl/t-6iQaqbnDkN
Last post December 18, 2019, 11:49:49 AM
by manulaudic
Last post August 25, 2009, 07:06:28 PM
by nhaudio
Last post April 10, 2012, 03:16:06 PM
by JohnRoberts
Last post December 13, 2010, 05:36:54 PM
by pucho812
