My goal is to basically build the "AIR" band & share it with the group.
The schematic I'm making (for now) will only be the fixed 2.5k band & the switchable shelf = 5k, 10k, 20k, 40k.
Although the SUB part sound very usefull too.
I may start breadboarding just the "air" band tonite.QUESTION: I mentioned a few times that the circuit is parallel = 1 is the raw signal & the other EQ - the EQ pots are summed using 5.62k resistors (6 TOTAL) If I ONLY build just the "AIR" band I won't need all the summing resistors :? BUT, won't that change the impedence :?: And how should I compensate or do I even need to :?: :?: :?: Thanks,Kevin
The stranges thing I can't figure out is the 2.5k on the high shelf & the switchable one don't seem to be using the same cap values...check it out please... but it is right.
Started by Mbira The Lab
Started by briomusic The Lab
Started by ytsestef The Lab
Started by abechap024 Brewery
