Purusha
3D "AIR" EQ - "Night EQ" PCB's Complete!
« Reply #40 on: January 13, 2007, 04:39:05 AM »
My goal is to basically build the "AIR" band & share it with the group.
Why not the whole thing?
Regards as always, Purusha
khstudio
« Reply #41 on: January 18, 2007, 01:34:20 AM »
Deleted
« Last Edit: February 14, 2010, 04:17:31 PM by khstudio »
Kevin ~ KHStudio
khstudio
« Reply #42 on: January 18, 2007, 03:10:02 AM »
Deleted
« Last Edit: February 14, 2010, 04:17:46 PM by khstudio »
Kevin ~ KHStudio
Purusha
« Reply #43 on: January 18, 2007, 06:13:31 AM »
The schematic I'm making (for now) will only be the fixed 2.5k band & the switchable shelf = 5k, 10k, 20k, 40k.
Kevin, not bad idea at all  :thumb:
Maybe I could make some nice 2U cases for 8ch. of 2.5k band & the switchable shelf = 5k, 10k, 20k, 40k. We could organize some PCBs order and have a group buy. I know how this AIR sounds and I liked it from the first moment I heard it.
Purusha
« Reply #44 on: January 18, 2007, 06:16:33 AM »
Although the SUB part sound very usefull too.
khstudio
« Reply #45 on: January 18, 2007, 07:04:26 AM »
Quote from: "Purusha"
Yeah, the sub DOES sound very good :sad:
Damn you :green:
K
Kevin ~ KHStudio
Purusha
« Reply #46 on: January 18, 2007, 07:13:48 AM »
Let's do the SUB as well  :green:
8channels of 3 band  :thumb:
khstudio
« Reply #47 on: January 18, 2007, 11:12:35 PM »
Deleted
« Last Edit: February 14, 2010, 04:18:16 PM by khstudio »
Kevin ~ KHStudio
khstudio
« Reply #48 on: January 19, 2007, 12:21:13 AM »
Deleted
« Last Edit: February 14, 2010, 04:19:05 PM by khstudio »
Kevin ~ KHStudio
clintrubber
« Reply #49 on: January 19, 2007, 04:08:35 AM »
Quote from: "khstudio"
I may start breadboarding just the "air" band tonite.
QUESTION:
I mentioned a few times that the circuit is parallel = 1 is the raw signal & the other EQ - the EQ pots are summed using 5.62k resistors (6 TOTAL) If I ONLY build just the "AIR" band I won't need all the summing resistors :?  BUT, won't that change the impedence :?: And how should I compensate or do I even need to :?:  :?:  :?:
Kevin
I'm not familiar with the exact functionality of this unit (a pic of the frontpanel would be nice, couldn't find a decent one).
But let's try: OK, so there's one 'dry' path to an output-summer and several parallel paths doing a certain frequency band ? If you only want one then no corrections needed I'd say. Since this is a pile of opamps doing filtering & summing all will be 'independent' I assume.
So just try it, I expect it'll just work.
Nice work !
Bye,
  Peter
khstudio
« Reply #50 on: January 19, 2007, 10:22:14 AM »
Deleted
« Last Edit: February 14, 2010, 04:21:14 PM by khstudio »
Kevin ~ KHStudio
Greg
« Reply #51 on: January 19, 2007, 10:55:23 AM »
Nice work khstudio. I'm gonna take look over this the next few days.
One thing I noticed, and it's very, very minor. It looks like you used the resistor symbol for the inductors L1 and L2. Look for a symbol that looks like a coil... looks like the primary or secondary side of a transformer symbol.
 :guinness:
Greg Stein
New Orleans, LA
clintrubber
« Reply #52 on: January 19, 2007, 10:57:22 AM »
Thanks for posting this  :thumb:
Is the sum-collection-point at the top-side of R31 (@U5) ? Label might be missing.
edit: no wait, I see 'EQ-sum'. But what's U5 doing ?
  Peter
peterc
« Reply #53 on: January 19, 2007, 03:45:12 PM »
Kevin
Check your email, I've updated a lot of the parts & the schematic.
I think U5 should be an inverting amp.
Peter
If opportunity doesn't knock, build a door.
khstudio
« Reply #54 on: January 19, 2007, 06:13:09 PM »
I'm in a session right now after getting about 4 hours sleep :sad:
Please post all the questions you want & I'll be back in a few hours.
I am aware that some corrections are needed.
Greg, I'll fix the inductor :thumb:
« Last Edit: February 14, 2010, 04:21:52 PM by khstudio »
Kevin ~ KHStudio
nielsk
do it all, baby
« Reply #55 on: January 19, 2007, 07:47:46 PM »
This is a great EQ, it's the poor mans GML. Leaving out the other bands would be a mistake! Please see it through and do a full unit, I have wanted one of these for a long time and would love to be able to build myself one.
« Reply #56 on: January 19, 2007, 08:30:31 PM »
Massenburg had said i believe that he put his bands in paralell
becuase it sounded better although it limited the max boost
 I have a schemo someone had made without the servos
Nice work KH
peterc
« Reply #57 on: January 20, 2007, 02:15:15 AM »
Here is an updated version with my idea of U5 - I'm open to correction....
DELETED
Changed some of the resistor values to match those on the PCB.
The stranges thing I can't figure out is the 2.5k on the high shelf & the switchable one don't seem to be using the same cap values...check it out please... but it is right.
I think they have done this to get different Q's.
I've simulated the values & they seem good for the bell bands, never sure of where the effective freq is for a shelf. The shelf EQ's are in the right ballpark though.
« Last Edit: February 15, 2010, 01:37:17 AM by peterc »
khstudio
« Reply #58 on: January 20, 2007, 02:48:40 AM »
x
« Last Edit: February 14, 2010, 04:37:16 PM by khstudio »
Kevin ~ KHStudio
khstudio
« Reply #59 on: January 20, 2007, 04:19:29 AM »
x
« Last Edit: February 14, 2010, 04:37:05 PM by khstudio »
Kevin ~ KHStudio
Last post December 18, 2019, 11:49:49 AM
by manulaudic
Last post August 25, 2009, 07:06:28 PM
by nhaudio
Last post October 23, 2009, 07:53:29 AM
by ytsestef
Last post December 13, 2010, 05:36:54 PM
by pucho812
