DIY D/A Converter Kit
paxworth
Member
Sarasota, FL
Has anyone ever DIY'd an A/D or D/A converter? I noticed the website below has a kit you can buy and put together yourself. Has anyone built one from ground up without a kit?
http://www.octave-electronics.com/Kits/dac.shtml
I need also to do a DA converter for 8 channel from my digi 192 I/O.
i've got 8 channels AES/EBU that i cannot use.
Where i can find 8 DA converters, in kit?
take a peep at the PCM4104 eval brd from TI - 8 chan dac right there...$199
http://focus.ti.com/docs/toolsw/folders/print/pcm4104evm.html
I'm hoping to use this chip in a dac soon :thumb:
that's what i like to hear!!!! :):):):)
Now tell me your going to build a million of them! :green: :cool:
R
P.S -- get ready for teh PCM4204 - 4 channel 118dB AD converter... the EVM will have 8 channels onboard :)
Kevin Carter has a new D/A kit. Check it out:
http://www.kandkaudio.com/digitalaudio.html
Once I made a DA converter from Norman Tracey kit--it was a killer.
Never seen AD kits--probably evaluation boards would be the best bet--try to search Analog Devices, Burr&Brown, and Cirrus Logic sites.
