ahh i see - could you provide a pic from the bobbin marking?
neumann often printed the turns count and wire diameter on their bobbins:
1300 turns 0,07mm diameter wire
100 turns 0,35mm diameter wire
so yes you are right its the special version, it has half of the turns count on the secondary - a 1:13 instead of 1:6,5 ratio...
if interested contact me for rewinding it to original specs.
