nIche
Member
Hi all,
First off, thankyou to everyone for the huge amount of PM1000 module racking info. I think I posted one power supply related question several months ago but since actually getting stuck into it I've been able to find everything I've needed on the boards without having to ask further questions. And this being my first DIY project, I've learnt a hell of a lot so big thanks again! I'm really enjoying it.
So after much labour, they're finally up and running. I was apprehensive on powering up for the first time but everything went smoothly - I think I got it right first go! Clean and quiet (much quieter than expected) signal passing through, phantom working properly etc.
Except When I turn up the EQs, especially the bass, I'm getting a large degree of 50Hz (Oz) hum/inteferance in the audio (or higher harmonics of, with the mids and highs). Likewise, the HPF switch is causing the same problem and both channels are behaving identically. I think a previous poster had this identical problem but fried his power supply before it could be solved.
I've uploaded a file to:
http://www.secondworldstudios.com/stuffz/pm1000 eq tests.mp3
Note that there's a fair amount of 50Hz present even when the EQ is flat but this file has been normalized with a lot of gain added. As mentioned, I was quite impressed with how quiet the preamps are.
The file plays in order -
1) Flat
1) HPF to 40Hz
2) HPF to 80Hz
3) HPF back to 40HZ
4) Flat
5) Bass boosted to 10
6) Bass cut to -10
7) Mids at 1k, boosted to 10
8) Mids to 2k, boosted to 10
9) Mids to 4k, boosted to 10
10) Mids back to 2k, boosted to 10
11) Mids back to 1k, boosted to 10
12) Mids at 1k, cut to -10
13) Mids to 2k, cut to -10
14) Mids to 4k, cut to -10
15) Mids back to 2k, cut to -10
16) Mids back to 1k, cut to -10
17) Flat
After reading previous threads and researching elsewhere on the board, I came to the conclusion that the hum is being caused by EMI from the power supply transformer. And if you see where I've placed the power supply this makes a lot of sense. Live and learn...
Another (short) file -
http://www.secondworldstudios.com/stuffz/pm1000 shield test.mp3
- is me moving a 3mm alluminium panel in and out between the power supply and the channel strips, while the bass is boosted to 10. Not doing a lot of course but clearly seeming to knock off some of the higher harmonics.
So I wired up another power supply outside the chassis, about 1m away and problem solved...no hum whatsoever. So an external supply is certainly one easy solution to my problem.
Then I moved the power supply in the case to the far right corner (where it should have been in the first place)...and it made a sizable difference (about 10-15db) but the interference is still much too loud to make the EQ usable.
The thing is, I've seen photos of several people's units in similar sized chassis with identical power supplies (Scodiddly, KHStudio etc.) and they don't seem to be suffering the same problem.
What I'm wondering is:
1) AFAIK I've grounded everything properly, adhering to advice in all previous posts and checked this very carefully, but is it possible I've missed something and could this be causing the 50Hz hum?
2) I never recapped either of the channels - could this in any way be causing the problem?
3) My DCV out of the power supply is 48.3V and post the diodes is 43V - one too many diodes! The circuit still seems to be operating fine but is there any way this could have anything to do with it?
1) Flat
1) HPF to 40Hz
2) HPF to 80Hz
3) HPF back to 40HZ
4) Flat
6) Bass cut to -10
17) Flat
