clintrubber
I've been thinking about a topology with an ON-OFF-ON switch and some capacitors for switching the cutoff frequency of a filter.
The arrangement with the smallest resulting cap-value in the middle position is a no-brainer, but obviously one would like to have a smallest-middle-highest sequence for the values.
So a small puzzle: which topology could realize an increasing cap-value between two terminals ?
I'm actually not sure it has a solution, since closing a contact increases the total cap-value both for (1) adding another cap in parallel as well as for (2) shorting a series-cap. But please surprise me !
The Rules:
The switch is a single pole, three positions, middle position keeps the pole floating (ON-OFF-ON) and you can use any amount of caps.
Negative cap-values, switch driven relays, balanced cross-connections etc etc are out.
Bye,
Peter
The Rules:
Bye,
Peter
