I have an 1176 that I built years ago that generally seems to be working well, but I recently measured the ratios and they are quite a bit higher than they should be. 4:1 was more like 7:1, 8:1 was 11:1, 20:1 was 33:1, etc.
I checked the resistor ladders around the ratio switch and they all looked fine, which makes me think the issue is in the gain reduction control amp that is fed by the ratio switch. But again no obvious issues there. I did notice that the GR control amp loads down this resistor ladder quite a bit, so the signal levels at those switch nodes drop significantly compared to when GR is switched off, but maybe that's normal? If not maybe the hfe of those GR amp transistors is too low?
Anyone run into this problem? I know I can just modify the ratio resistors to get the ratios I need, but when testing that out I had to change them so much that I'm suspicious there's a larger problem.
