seavote
my project is progressing.psu trannies are mounted and hooked up. pcb(gustav)populated and installed. i'm about to wire up the xlrs and 3 way switch. i want to see if i understand the grounding for the project correctly. gyraf writes
"Connect power gnd to signal gnd at the output xlr."
as i understand it i will wire the ground lug on the output xlr to the ground lug on my ac inlet. the ground(0v) coming off the pcb goes to the mic via pin 1 of the 7 pin xlr and to the output via pin 1 of the output xlr. is pin 1(0n the output xlr) connected to the ground lug internally in the xlr? if not, i dont understand where the 0v rail finds its way back to earth ground. should i jump the connection bteween ground lug and pin 1 on the output xlr?
somewhere in the metas gyraf also wrote that heater 0v,ht 0v should be grounded at one point preferably in the mic.
i understand this to mean pin 1(ht ) and pin 7(heater) should connect with the transformer ground(as shown on the schematic) on the mic body. is this correct?
