Well I took a deeper look and would be interested to hear your opinion. This is what I see. 1st off the black cap is not epoxy it is plastic, below that is epoxy.
1) Resoldering to the existing base of the pin does not work. The pin appears to be coated with what ever and solder will stick to that. However, the material of the pin itself from the outer wall to the center is not consistent and is an alloy I believe. Bottom line, aint shit gonna stick to it as far as solder goes.
2) The only way I see to put a bandaid on a situation like this is to drill thru the epoxy with a tiny jewlers drill bit, and solder at the lower base of the pin at the point of connection where the wire is attached to the pin. At this location the material is solder friendly. Off course by the time you do all this you could have made more money working at a hamburger stand and just replaced the transformer.
But , thats not the DIY spirit is it? :green: It's to interesting to learn more about these little Gems.
Anyway thats my thought. I have pics now of the inside of the trannsformer which I will post asap. You really can't fuck with this too much. It's almost booby trapped. If you lift the black plastic cap off, the one that holds the pins, the ground wires... about four that I saw would be ripped away. There is no slack ! So, full on disassembly would tear it up.
My conclusion:
Micro drill a hole and re attach below the base of the pin. Hope this makes sense.
:thumb:
Im finished it works it's loaded wired and rockin. One more to fix. I'll wait CJ probably has a better idea.
A little bit of putty a little bit of paint, "Make it what it aint"
Trying to get some good close up pics so the group can use them if need be. Having a hard time getting good focus very close up with a small item.
