khstudio
I'm reverse engineering an EQ3d & have 90% of the parts figured out but -
I NEED HELP!
How do you read SMT Resistors :?:
How do the codes work :?:
Some of them have what appears to be an 8... but the two circles aren't connected... like a % sign with NO slash & the circles straight up/down???
EQ3d - PICTURES & FILES LINK:
http://www.twin-x.com/groupdiy/thumbnails.php?album=72
I got this responce but it didn't answer the above question:
Kevin
I NEED HELP!
Quote:
It uses SMT resistors with very small numbers.... I've never had to figure them out before, HOW
SMT resistors are coded similar to color bands on a thru-hole resistor.
4 digits usually=1%
3 digits usually=5%
Example:
102=1K 5%
1001=1K 1%
Anything under 0603"(.060"X.030") will not be labeled. Usually 0603 and larger jumpers are labeled 000
Quote:
Also, some of them are just plain "white" are they just "zero ohm jumpers?
SMT ceramic caps are almost always not labeled. You would have to remove the cap and measure with a LCR meter to know for sure. Same for 0402 and smaller resistors.
Tant caps are sized "A case" "B case" etc. but usually have the same type code, or they have the actual value printed.
Vetsen
Kevin
