the latest victim..
BH curve, low level, so into the noise floor a bit:
Even though the overall size is small to begin with, there was another can inside the can!
Clever use of two cans to get max shielding with min space.
No wonder people say these are quiet.
The signal from a ribbon motor is probably the lowest level that gets amplified in a studio, so in order to keep the s/n good, you need all that mu metal. I just went at it like a can of sardines.
This is looking at it from the top, with the top can pulled off, and the second, inner can exposed. There was just a small dollop of epoxy like compound that loosened up with the heat gun.
http://vacuumbrain.com/The_Lab/TA/Beyer/Ribbon_Transformer/beyer_ribbon_c.jpg
They say keep it small for max bandwidth, I guess they were not kidding.
This is definatrly the smallest xfmr I have "worked" on.
A round nylon bobbin is used. Same thing with SM 57 xfmr.
Pri wire on outsde, 9 or 10 turns, will find out shortly:
Got the micro workin, so more exact wire sizes from here on out!
This is your first, precicion, DIY xfmr hack job, ribbon primqary wire gauge:
I just figured out that the reason the pri is wound last is because the wire is so thick that the bend radius would make it impossible to wind
around the inside of the core without taking up too much space, which would also mean more leakage, since there would be more air in the winding.
Also, this core material is probably hi mu something, even though it looks like grained silicon from the outside. If you wrap that big wire around the core too tightly, you can alter the magnetic properties of the core material due to mechanical pressure. I was reading about this on the Magnetics web site, which has a lot of good info in their online library.
They even have to watrch the epoxy that is used to encapsulate some of the powdered cores. If the tempeture coef. is wrong, the strain will decrease inductance. Ask Svart what this does to a tuned switcher.
