living sounds
Hi folks,
I've got a device (Lexicon Nuverb) that is very picky about its input. It needs a 100% to-spec AES/EBU signal to operate. For instance, it did not accept the input from the Multiface in AES-mode.
I've found converter schematics on the web, but they only cover the impedance and voltage part and thus don't affect the 'bits'.
Is there a simple circuit (using a - preferably cheap - standart IC) to do this? I've found some of mcs's schematics, but I'm not sure if they are what I need and how to implement it properly.
Thanks alot!
Gregor
Thanks alot!
Gregor
