Jazz
La2a problem - Touch down ! Problem resolved
« on: February 10, 2007, 03:19:47 PM »
Hello folks, I have a problem on an La2a that I have not been able to track down yet and, was wondering if someone might have a clue or tip that could help me resolve this. Here is some info.
All the voltages at the standard test points on the schematic / tube sockets appear normal. What's happening is the VU meter starts to flutter back on forth when the gain pot is turned. I think I'll change the pot because I just noticed that you dont even have to turn the pot to trigger this fluttering.  Just snapping it with the finger can also cause it to flutter.
As you may know I've built about six of these so far and have had only one that had a ground problem. So I'm scratching my head. Off to change that pot now.
Nope, not the pot. Thought I found it. Still flutters.
Thanks, ~R
 :shock:  :thumb:  :green:
dripelectronics
« Reply #1 on: February 12, 2007, 02:13:22 AM »
that would be a problem located in one of the components that go to the T4 ground , meaning somethings not grounded right.
resolder all of the components that connect to that ground.
g.
g.
[email protected]
(not so good with PM's so dont pm...use email)
la2a ver 3 atoms manual : http://lomayesva.com/la2a_pcb_ver3.pdf
v72 manual : http://lomayesva.com/v72_pcb_manual.pdf
Jazz
LA2a
« Reply #2 on: February 19, 2007, 12:36:32 AM »
They check good with the ohm meter but I'll do it. THanks for your help, I'll let you know what happens.
SSLtech
« Reply #3 on: February 19, 2007, 08:16:22 AM »
...is the meter in GR or +4?
"A waist is a terrible thing to mind"
Quote from: PRR
Ah, but that was 1999; we don't party like that any more.
Jazz
« Reply #4 on: February 19, 2007, 10:08:37 AM »
Meter is in +4 mode
When the gain pot is at 0 zero the meter is fine. When the gain pot is turned slightly the meter flickers back and forth.
JdJ
Me too
« Reply #5 on: February 19, 2007, 10:49:21 AM »
Mine kind of does the same thing, although I haven't heard it affecting the sound.  Touching the front panel doesn't seem to do anything to affect it as it does with yours.
I have always suspected that it was caused by some oscillation- I just haven't had time to troubleshoot.  Maybe try:
http://www.groupdiy.com/index.php?topic=43559&highlight=la2+oscillation#43559
On mine I didn't use the grid stoppers and I am using the Sowter iron, so I was thinking it might have something to do with that...
Grid Stopper Info
Let us know what happens!
Josh
Jazz
« Reply #6 on: February 19, 2007, 03:34:05 PM »
It actually does not flutter when the pot is flicked with the finger, it does have to be turned...
I was wrong about that. Will look into this,thanks Josh
Jazz
LA2a my voltages
« Reply #7 on: February 19, 2007, 04:59:49 PM »
V1
1 - 118v
3 - 1v
6 - 125v
8 - 1.1v
V2
1 - 97v
3 - 4v
6 - 220v
7 - 73v
8 - 96v
V3
1 - 99v
3 - 0.8v
6 - 98v
8 - 0.8v
V4
2 - 6v
5 - 155v
6 - 115v
David Kulka
« Reply #8 on: February 19, 2007, 10:30:30 PM »
I would first look for DC on the high side or the wiper of the pot.  There should be no DC on this pot but if any is seen, determine the source will lead you to the problem.
if it's not DC it's probably oscillation.  Check lead dress, grounding, etc.
Jazz
re DC
« Reply #9 on: February 20, 2007, 12:18:43 AM »
Thanks for your reply David. Well..... I feel a bit stupid but then I never claimed to be skilled in this area...after all I'm a musician. This is my point.
How the heck do you do that? I do have a scope. If you have time to explain it that would be great, If not, no worries. I've tried all the advise listed so far ...but only a fast version of moving wires a bit with chop sticks. I would like to try
that some more. But then all my other units did not have this problem and I
have not changed much really. If anything they are wired better I would think.
I don't really know what oscillation would sound or look like but I do feel it is oscillation.
Description of what's happening on more detail.
A) Gain knob is on zero, when you increment it a bit the meter flutters back and forth like a ball bouncing back and forth between two walls that are close to each other.
Sonically, there is distortion. If I apply compression it sounds almost normal. I've checked wiring very carefully and inspected the unit under a magnifier several times.
~R
Jazz
Found the problem
« Reply #10 on: February 20, 2007, 02:00:35 AM »
Bad capacitors   C2 and C3   0.1uf/400v
Ok this is the story. I had a box of these old caps that I got from a surplus store when I purchased a box of stuff....well I wanted to try these caps to see how they are. I suspected these damn caps three weeks ago.....so I pulled out the capacitor tester and they both tested out at ~ 0.15uf
Then I pulled out a couple of  my orange drops caps and they tested out at 0.1uf right on the nose..... so I can assume my cheap old cap tester is not so bad.  Changed the caps and the problem vanished.
What a pain in the butt. Thank you all for your advise, I really appreciate it.
~R
 Now  I can sell this clone on ebay. JUST JOKING  :green:  :green:  :green:  :green:  :green:  :green:  :green:  :green:  :green:  :green:  :green:
So anyone who plans to build an La2a.
Don't cut corners on the caps. It only took 0.005uf of an offset to cause the La2a to get upset, Is that math right? I dont know I cant see straight almost time for bed
Re: Found the problem
« Reply #11 on: February 20, 2007, 04:55:49 AM »
Quote from: "Jazz"
That is very good advice!
I would go a step further and say "never cut corners on any components"!
Whats the use of spending lots of hours making supposed high end clones or other constructions if you waste the result with lack of quality components. Because thats what the real high end equipment are made off.
Its not just only schematics...
Purusha
« Reply #12 on: February 20, 2007, 05:17:11 AM »
V1
1 - 118v
3 - 1v
6 - 125v
8 - 1.1v
V2
1 - 97v
3 - 4v
6 - 220v
7 - 73v
8 - 96v
V3
1 - 99v
3 - 0.8v
6 - 98v
8 - 0.8v
V4
2 - 6v
5 - 155v
6 - 115v
That's funny. I have almost the same voltages across the tubes in my LA-2A. I gues I'll have to check the cap values as well.
Regards as always, Purusha
SSLtech
« Reply #13 on: February 20, 2007, 08:52:08 AM »
Were they Ceramics or something?
Keith
Quote from: PRR
« Reply #14 on: February 20, 2007, 10:46:16 AM »
Proabably has nothing to do with the offset in cap value, and everything to do with DC the caps were leaking.
I see this all the time with old caps (even NOS), and not found a clear way to detect it other than a cap change revealing a bad part, which still test good with a meter.
Jazz
« Reply #15 on: February 20, 2007, 04:57:40 PM »
Yes they where ceramic, How ya doing?
 :green:
Jazz
« Reply #16 on: February 20, 2007, 05:05:47 PM »
Yes
Last post January 27, 2012, 12:06:58 PM
by kilmister
Last post March 31, 2012, 04:06:00 PM
by Seeker
Last post April 13, 2012, 08:31:34 AM
by squib
Last post May 29, 2012, 02:56:43 AM
by smallbutfine
