Minion
Howdy Folks, I thought I would share a small Project that I did today durring a couple hours of free time and inspiration that I had.....
I had a Bunch of cheap Electret elements laying arround and some 6418 Sub Mini tubes from a Project that I never started so I thought I would see if I could make a Tube mic out of them useing the body of an old Dynamic that I killed....
Here are a few Pics of the mic and the Curcuit (slightly modified version of someone elses design)...
The Mic has a very nice nice warm sound with a very detailed low end but the high end is a bit lacking probably because of the crappy capsule.... I am actually very pleasantly surprised that this $5 in parts makes such a nice sounding mic and with a better quality capsule it sould sound much better....
The mic has an extremely hot output so you don"t need hardly any gain before clipping so a 10db pad switch could be probably added pretty easilly....Also the Transistor I used was the BC550C but Others could also be used .....
The PCB is only 1.5in x 1.2in and should fit in the body of most regular mic bodies but could also be redesigned to be smaller, PCB design isn"t my strong point....
So if anyone needs a useable Tube mic that can be made for about $5 in parts this is a Pretty good and easy project to do and it is probably one of the only tube mic designs that run off of +48v Phantom power.....
