pgorey
New member
All right, i'n new to DIY and I ran into a problem. While trying to solder on some wires and a few components, I seemed to have burned off a couple circular solder points on the PCB. The wires and compnent pins were all close together and I was trying to remove excess solder by heating it up and sucking it off with a solder remover. Anyway, I'm wondering if there is a way to fix the connection point...dare I ask if there is an epoxy that works as a good conductor...If the ring is missing, does that mean there is no more connection possible where that component pin / wire is?
