Has anyone ever had problems with a click/pop sound sound when the phantom power is engaged on a neighboring channel? It's very low in level and I hear it more when the channel's gain is 3/4 on API-312 type preamps.
I am using my Relay PCBs in this setup. The phantom is not actuated by a relay but by a switch on the front channel. The circuit is your basic 240 Ohm resistor to a 220uf/100V Coupling cap and 6.81K resistors. The grounding seems like an adequate star ground setup.
Has anyone had this problem with my PCBs? If so, hopefully I can find a workaround to what I did wrong.
