IzzyRock
LA2A PCB ver 2.0 build thread
« Reply #280 on: October 17, 2008, 01:24:25 AM »
Question regarding meter.. please anyone.
Im sending a signal to the compressor, showing 0db at output mode.
Then, if I compress it 5 dbs shown on GR mode, on +4 it shows 2.5db output.... it should be equal.. shouldnt be it?
Now.. if I compress 10db... it outputs 5db......20--->10... its proportional
Is this normal??
Arrigotti
« Reply #281 on: October 17, 2008, 02:37:55 AM »
What do you mean by "hinge"? Sorry, my english is not 100% great hehe
Could u explain a bit more please?
The originals as well as the new reissues have a hinged front. (like a door)  ....tiene una bisagra como una puerta...
JoleFIN
Re: LA2A PCB ver 2.0 build thread
« Reply #282 on: February 23, 2009, 05:06:47 PM »
Does anyone have the drip_opto_manual.pdf ? The lomayesva.com link doesn't seem to work anymore. Would be thrilling to get to build an LA2A now that I'm almost finished with my first DIY SSL compressor :)
-Jole
Grooveteer
« Reply #283 on: March 07, 2009, 02:10:22 PM »
Hi Guys,
Just finished my LA2a (Drip 2.0) today.  It doesn't smoke, passes audio and even compresses, but...
The VU (Sifam AL29) does not work in gain reduction mode.  (seems work OK in +4 mode)  The neon lights up and I can adjust the needle to 0dB but it doesn't move.
Any clues?
G
mac
« Reply #284 on: June 29, 2009, 05:29:24 AM »
yeah,
I am chasing the Pdf also....if anyone has a copy...
Barclaycon: The client said 'That sounds great, what are you using on it?'
The engineer's reply was: '30 years of experience'.
Orientation of the trim potis for stereo adjustment and limiter response
« Reply #286 on: December 29, 2009, 03:01:14 AM »
i'm about to solder my Opto 3 board and got a question concerning the orientation of the trim potis for stereo adjustment and limiter response:
I'm wondering, why this trim potis are orientated the way the manual shows...Why doesn't the "3" labelled on the potis have to be align with the "3" labelled at the PCB? (see attachment)
In case of the zero adjustment poti it is...
Is this an error in the manual or is it correct this way?
I've got other trim potis than the manual/Bom lists and my trim potis are labelled with "1-2-3"...so do i also have to turn the potis of stereo adjustment and limiter response in a  way that the "3" of the potis is align with the "1" at the PCB?
Best regards
Daniel
« Last Edit: December 29, 2009, 03:07:17 AM by basementmedia »
canidoit
Re: Orientation of the trim potis for stereo adjustment and limiter response
« Reply #287 on: December 29, 2009, 03:24:03 AM »
Best regards
Daniel
I had problems with that area that caused my unit to play up when I finished building it. This could be an area that you should investigate if you have issues with your unit when you turn it on. I rewired mine backwards and adjusted the zero adjust pot to help me resolve a VU metering issue. Took a while to find out that it was a cause of an issue.
iva dunit formerly known as canidoit
« Reply #288 on: December 29, 2009, 05:04:48 AM »
sorr, my english is not so good.
do you mean that i should solder it by default as shown in the manual (which means that the "3" pin is align to the "1" marking of the PCB) or otherwise?
best regards
Daniel
substitute
« Reply #289 on: December 29, 2009, 08:58:44 AM »
I may be wrong it's been a little while since I built mine but...
Pin 2 of the trimmer (or pot) is the wiper.  This is the important connection, the other two are interchangeable.  The only difference will be   which way you turn the pot to adjust.  For example if you had a volume knob and switched pin 1 and 3 connections "turning it down" would increase the volume.
If you compare the data sheet of your trimmer to the schematic, and then trace that on the PCB you'll be fine
juanjovincenzo
« Reply #290 on: January 01, 2010, 05:17:19 PM »
Hi guys,  simple questions.... What is the better LA-2 PCB (or what are the better option to choose), And Where I can buy????  Maybe are a PCB for two LA-2
Is the Drip electronis the only dealer???
thanks
regards and happy new year
Juanjo..
Recorder and Mixer
« Reply #291 on: January 01, 2010, 08:27:12 PM »
thanks
Juanjo..
I heard a friends Drip La2a with Sowter transformers and I can say that this unit sounds excellent! It's pretty quiet compared to my P2P La2a. Though the difference probably is due to the original transformers versus the Sowter ones in the Drip La2a.
We use the Drip La2a to track and the Point to point La2a to mix with.
« Reply #292 on: January 02, 2010, 12:21:41 PM »
Quiet as in less noise than the P2P, or just lower output due to lower ratio input iron??  Just curious, thanks.
ben
juanjovincenzo
« Reply #293 on: January 02, 2010, 02:45:44 PM »
Where is the link to read about the Point to point La2a board
regards
Recorder and Mixer
« Reply #294 on: January 02, 2010, 04:03:10 PM »
ben
Less hiss and hum.
Here is Kayacosta's diagram for the point to point.
plimousse
« Reply #295 on: September 18, 2018, 11:34:41 AM »
Hello everybody,
I resurrect this thread because I bought a pcb VER2.0
I am looking for all the documentation possible to build this compressor
Thanks for all
Kind regards,
Pascal
Rob Flinn
« Reply #296 on: September 18, 2018, 01:00:21 PM »
I have this pdf.  PM me your email & I will send it to you.
regards Rob
plimousse
« Reply #297 on: September 19, 2018, 05:44:21 AM »
Hi All,
Problem solved.
Thanks a lot to Rob
Pascal
plimousse
« Reply #298 on: August 07, 2019, 12:08:23 PM »
Hello everyone,
There is an alignment procedure for this unit ?
Pascal
plimousse
« Reply #299 on: August 19, 2019, 06:11:56 AM »
Hi All,
Im sending a signal to the compressor, not signal on output ...
The signal pass until C2, not after ???
Anyone have idea ?
Thanks a lot
Pascal
Last post June 01, 2007, 12:40:42 AM
by rodgre
Last post November 03, 2010, 01:51:16 PM
by pH
Last post January 13, 2009, 11:25:19 AM
by Arrigotti
Last post January 27, 2009, 08:30:16 PM
by Bill Kahler
