Just when I thought I was out of questions, I have one more.
I just found a grayhill on digikey that looks ok, but I'm unsure about the amp rating requirements on this switch. The one I found is 200mA, but it's less than $11, so it may be worth it if it will work.
EDIT: BAD PART NUMBER REMOVEDCan someone tell me what the amp rating needs to be for the switch?
Also, a thanks to AnalogPackrat. I found another CTS on digikey that looks like the same thing, but with 12 positions.
EDIT: BAD PART NUMBER REMOVEDI think I'm pretty determined to get better switches in this thing. The Lorlins work great for the GSSL and the G1176, but I'm not liking them at all on the Green Pre. I must be crazy too, cause I hated soldering those resistors to that switch.
Matt
