Amp Optimize
Soeren_DK
Denmark
I have this Traynor YVC-40 40watts guitar combo who needs a little optimize. The bright and soft sound in the amp is killing me and I search for a little more dirty sound in it.
The diagram is here.
http://www.mentol.dk/diy/schem/traynor.gif
I have bought new tubes but not jet put them in.
Three 12AX7 Tung-Sol for the preamp stage and two Svetlana 6L6GC for the power stage.
Soeren Sailor
Link didn't work for me.
A pedal in front of it won't do it for ya'? Another option is to mess with the bias until there's enough crossover distortion to cut hardwood. Makes a lead break cut through the mix.
[quote author="mikka"]Link didn't work for me.[/quote]
Weird. It works for me. Do you still have the problem?:?
[quote author="mikka"]A pedal in front of it won't do it for ya'? Another option is to mess with the bias until there's enough crossover distortion to cut hardwood. Makes a lead break cut through the mix.[/quote]
I tried a lot af pedals but nothing works well enought to do it. I have change the speaker and It helped alot but the amp is still to soft. I dont now how to adjust the bias for the tubes?
Soeren Sailor
[quote author="Ptownkid"]Wow, that's wierd. When i worked for yorkville I brought one of those home and was really impressed by how much it rocked...[/quote]
Have you changed the tubes?
Soeren Sailor
Try 3 silicone diodes in parallel with R109 resistor (2 in series in parallel with another going in opposite direction)
1N914 for example.
Edit: R109 resistor
[quote author="Soeren_DK"]Have you changed the tubes?
Soeren Sailor[/quote]
No, it was completely stock, right off the shelf.
Which speakers came in yours?
