[quote author="radiance"]Hi JH,
I've downloaded the demo version and compared to Eagle it's a breeze.
I was wondering though...do you first make a schematic (using Rimu schematic) and import a netlist or do you start designing the pcb straight away withouth making a schematic first?
I find the tutorial quite understandable but working with a netlist was to much for my newbee brain. I could not make a sensible layout with that example they suplied...Just too many components and traces... :?
Tell me, what's a good way to start?[/quote]
Can't say what would be a good start, 'cause everyone is telling me I'm doing it the wrong way ... :?
I've never used a netlist.
When I started making pcbs ca. 20 years ago, with enamel paint on bare copper, there wasn't such a thing as a netlist. I made the component placement with pencil on chequered paper, and when everything was ok, I re-drew what would become the copper traces with a permanent marker on the paper. The permanent marker would shine thru, and I could redraw it again from the back side of the sheet. Then I fixed the paper to the raw pcb material with Tesa film at the edges, and drilled all the holes thru the paper into the pcb material from the copper side.
Then, with these holes as orientation, I painted the traces on the copper with enamel paint, using a fine brush. That then was etched in my kitchen.
But you didn't want to hear that. :grin:
What I wanted to say is that over the years I've learned to read my own pcb layouts as well as a schematics drawing. (It would certainly be different if I'd done more digital stuff; but in analogue, how many different opamp pinouts are there, really?)
Today it's not that much different. I simulate parts of the circuit, and obviously have schematics for that; and other parts are sketched in free hand. But I rarely have a finished schematics drawing when I start making a layout (or, in these years when I built on veroboard instead - it's not that different from designing a pcb for me). Some decisions are made during layouting: If there's no place for a couling electrolytic cap, I may just specify a low-offset opamp in the previous stage instead, rather than starting over with new placement or larger board size. :twisted:
There is some risk to simply forget something when you work without netlist. I'm well aware of that. So I force myself to double-check:
I route everything with 12mil (0.31mm) traces first (except GND with 1mm, and +/-15V with 0.7mm). When everything is finished, I sleep over it, and when I can look at the design with a fresh mind again, I'm making all the traces broader, where I can. So the signal traces are all manually increased to 0.5mm (unless I really need 12mil to go thru IC pins etc.), and while doing so, I check the connections again. Found 2 errors in my recent frequency shifter board that way. I hope I found all errors - I'll only know for sure in a few weeks when I get it back from Olimex.
JH.
