Arrigotti
I've been troubleshooting a DIY amp that a friend of mine got it way over his head with. It is passing sound, but with really low output, and seems to die away when you try to hit it with a strong signal.
Yes, I changed the tubes.......
I have several hours of troubleshooting into this, and have decided to just unsolder all the tube, power, and pot connections, and start from scratch.
I have suspecting a bad Output Transformer since, the get-go, but I'm not sure how to test that. I measured the resistace on the primaries and secondaries, and here is what I got:
Primaries with a center tap:
Once leg to center tap: 133.9 ohms
Other leg to center tap: 136.4 ohms
Outside legs: 270.3 ohms
Secondaries have only one tap: .5 ohms
I'm not sure if the secondaries should show such low resistance, but I could be wrong.
Any input would be appreciated.
thanks.
thanks.
