RFT 7151 Bottle microphone
ubxf
los angeles
Hello,
Is anyone familiar with this microphone and what it takes to make the
power supply external
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=64449&item=3744891320&rd=1&ssPageName=WDVW
Best Regards
francois
I don't agree with their expert's story! Sounds like something is faulty in there and it needs fixing rather than a big conversion job.
See if the seller will give you photographs of the capsule condition before you part with money.
Stewart
I wonder if those are VF14-tubes?
Jakob E.
Last time I saw such a mic was with EF12 tube. The other is probably EZ11 or something like that, because PSU is in the microphone.
It looks a little like a 1940s US radio inside. And after 60 years, these all need new power filter caps. And of course it will hum with the covers off: time to figure out what shorts when the cover is on.
While having the AC supply in the mike body sounds like a dumb idea, this was not a cheap mike and I'm sure it didn't hum (much) when working right.
The electronics are likely fixable, and probably simple.
The capsule could be like-new, or useless.
If you think the "looks" are worth $850+, go ahead and get it. At worst, you drill-out a rotten capsule and put in a $2 Panasonic capsule, hide a 9V battery inside that ample case, and run an XLR out. Since nobody you know has another mike like this, they won't know that it is bogus under the skin. (Oh... you might need to leave the power cord on, wired to a 7W light bulb in the case, so it "gets warm" like a tube mike should.)
actualy i already have one like this, i included the link for the pix.
mine works like it should but the fact that the power supply is in the mic
results in a pretty loud 60hz hum there is a pot to try to minimize it
but it's still close to unusable. i guess they were designed as a PA mic
so the line level that comes out of it was more important than the hum.
Anyhow do you think it's worth making the power supply external ?
i have a schematic if anyone is interested
thanks
francois
Fix what's there before you go hacking externally.
The large electrolytics are surely decayed. The rectifier should be checked or just replaced.
[quote author="ubxf"]actualy i already have one like this, i included the link for the pix.
[/quote]
First, I would replace this huge selenium rectifier with something more modern and compact, so you get more room inside. Then make a little board for regulated filament. This, as well as new electrolitics might take care of most of the hum.
Of course, you can make an outboard PSU, but... it wouldn't be RFT 7151 anymore. Also, resale value most likely will drop.
I commented to a degree on another thread in regards to this. Ive updated all my old tube mics with modern power supplies and havent in a single instance looked back. If you are using that mic to make recordings, if it were mine, I would take the supply out, put it in a box, label it and forget about it. Build a whole new supply from scratch and put it in an external box. Whats it gonna be, WORSE than the low freq hum that you have now. Thats what I would do. Of course, once you do that, some vintage collector wont give you a "fair" price for it, but those people are running a museum in most cases... Oh, you recapped it, you ruined the vintage value...
dave
the guy from www.vintagecity.de has one, with external power supply. says the tubes are ef12.
RFT7151 Schematics:
http://img.photobucket.com/albums/v172/gyraf/RFT_cm7151_2xEF12.gif
http://img.photobucket.com/albums/v172/gyraf/RFT_cm7151upgrade.gif
(Thanks to Francois!)
Jakob E.
Hi, I'm a new member and I'm a proud owner of a CM7151 RFT bottle mic. I want to make a few mods like taking out the power supply but on the mod schematics provided by Francois, I noticed a lot of differences with the original. Can someone help me understand this ? The other point is to read a few resistors values on the mod schematics...
My friend/co-worker just bought one of these. He's sending it to Korby for an overhaul/power supply removal. I'll have him take pics to document before and after. :thumb:
I modified my RFT bottle using the original schematics and just building an out board power supply inpired with the gyraf mic one (just a few values mods). It works OK for now but the real tests will occur this week-end. At the moment, I can say there's a pretty low noise floor even if it is really upper than a solid state mic. I will keep you informed...
I checked my new baby with a three different singers and I can say now that the RFT bottle with a M7 doesn't suit to every voices (even if it's always good)... The output level is huge with a solid state input mic preamp (focusrite green) but is more classical with a transformer mic input (avalon VT-737). I do really preffer this mic with the avalon even if I preffer to use the focusrite with a 414... So, I'm still in love with my mic, more than ever, because when it suit to a voice, the sound is really really wonderfull. My mod is OK, no hum or noise I can hear (the headphones noise is louder) but I really would like the exact voltage I can apply to the tubes. The caps of my mike was so dry that I'm not sure about the measures I made ... It seamed to be 130 Volts... If someone can measure this on an unmodified mic, I would be glad.
Hi Lolo,
I`m modding my 7151 with the help of Mr. Andreas Grosser. He is one of the most more experts in bottle mics and we had some conversations about the original cm7151. If you are following the original schematic the mic goes to 10k only, not suitable for studio use... I`m following the "neue" schematic with some values changed as Andreas told me. Also the original output transformer is lo quality and you must change it for turning it in a world class mic :thumb: just email me if you need more info!
About the PSU I`m thinking in reuse one from the "thomman2 T-bobe tube mic, it is 200 and 6.3V output. The Ht is ok but heater voltage must be changed to -6.3V. Also I have a G7 board set here, so maybe I can build the modified G7 too... What values did you change? and also how did you get the negative 6.3 v?
Synthi.
[quote author="synthi"]The Ht is ok but heater voltage must be changed to -6.3V. [/quote]
Why is it negative?
I don't understand why it would make any difference if it is only for the heater?
I was thinking the same about the negative voltage but someone told me that "is" required... :shock:
I`ll ask why...
Synthi
In Jakob E post
The first schematic is cathode biased
the 2nd is fixed bias (first stage) using a voltage divider on the -6VDC heater to optain the - bias voltage. NOW there is a way to do fixed using + heater voltage, look at the fixed bias M49 schematic and other neumann schematics to see.
