G
Guest
Guest
30 years ago I was young and stupid and invented Watt*Percent, i.e. power multiplied by THD to compare apples and oranges, now I don't think this measure is valid because harmonics need to be weighted, i.e. they need to have own coefficients of nastiness, and the higher is power the more excusable are distortions.
So, this will be better: WD = (L2*k2+L3*k3 + ...)/P
where L is power of the harmonic, k is coefficient of nastiness, WD is coefficient of Weighted Distortions. For the beginning, k may be equal to the number of the harmonic.
So, if to simplify, WD = ( L2*2 + L3*3 + L4*4...)/P
Curves for different amps would be interesting to see (power horizontally, WD vertically). The ideal amplifier should have always WD as close to 0 as possible.
