I was looking at some other posts where people seem to be having similar issues that I am. I just finished an 1176 using mnats boards, and I went through the calibration process outlined on gyraf's site. After setting the 0 VU mark when no signal is passed in with it in GR mode, I then switched over to calibrate a signale at 1:20 ratio. After I set the gain tracking to show -6 db, the 0 mark now reads close to -3. When I set it back up to 0, the GR setting now only shows about -3 for the -6 db of gain. I've tried tweaking both R54 and R55 pots to no avail. The gain reduction always seems to be off by 3 db or more.
Is it possible the pots need to be different values than what are listed in the schematic now that some of the other parts have changed? I am using TrueRTA along with Adobe Audition and a voltmeter for the calibration process. This same setup worked like a charm on the SSL box I built.
On a side note, I notice that the toroid transformer I have hums pretty loudly when it's powered on. It doesn't seem to affect the audio signal at all, but it is audibly noisy when you're standing close to it. I verified that I'm getting the proper +30 and -10 voltages at the right spots on the board, so I don't think there's any issue with the power supply section itself. Is it possible the transformer is too small for the circuit, and the excessive power draw is causing the buzzing? The transformer does not heat up like I would expect if that were the case. It is the Digikey Amveco toroid 62042 that provides 417 ma at 24 volts.
