mfdu
ok. so the little 5W epiphone valve junior is fab. but even at 5 Watts, it can be too loud.
i've had the unit a whole three days, and now it's time for the first mod.
so - what do i need in order to build and fit a passive variable attenuator (L Pad / power soak) ?
i presume more than simply a 5W (50ohm?) pot is required?!
any advice would be appreciated.
chris
mfdu
edit - would this do? ER - 10 Watt Monaural Volume Level Control (Audio L-Pad) www.rsaustralia.com stock # 2508977497 - $19.90
2nd edit - www.jaycar.com.au - 50 Watt RMS Fader - Mono #AC1672?? - $19.90
chris
mfdu
