1176 and OEPs, what ratio did you choose?
Hi Pususha,
I think for OEP transformer the ration is 1:2. You can check at Mnats site.
Here is a link
http://www.geocities.com/m_natsume/1176_revision_j.html
Regards
Dinesh
I bought four OEP A262A2Es to use in my stereo 1176 as listed in the bill of materials here:
http://www.geocities.com/m_natsume/files/mnats_1176_bom.pdf
As far as I know you can change the ratio of these transformers from 1:1 to 1:2 by flipping them 180 degrees in the mnats PCB before soldering - more info here:
http://groupdiy.com/index.php?topic=4080&postdays=0&postorder=asc&start=15&sid=ba9113166d5d86b90295733fd79be832
It appears that the best orientation is 1:1 on input and 1:2 on output, when I get all the components together to finish my 1176 that's the way I'll do it. :green:
