thermionic
- Joined
- Jun 3, 2004
- Messages
- 1,671
Following on from this thread, I am now in the fortunate position of not having Radio Moscow superimposed over records when I play them (5 different values of PSU bypass caps were used in conjunction with coaxial-shielded power cable).
The preamp *seems* to be quiet, as far as phono preamps go, but…it’s nowhere near as quiet as the single stereo preamps I’ve made in terms of 100Hz ripple (UK mains is 50Hz)…
I realise that having 3x as many preamps in a case means there’s a lot more going on in terms of ground currents… Grounding protocol as follows (the preamps are in a 1u case – the noise floor is exactly the same whether I use an external lab PSU, or dedicated PSU):
Power (5-pin XLR) – pin 1 is Ground. 2 is +Ve and 3 is –Ve
Pin 1 has a thick (approx 2.5mm) copper bar welded to it which runs across the length of the chassis for distribution.
ALL Grounds return to the copper bar.
I have noticed that the hum is least noticeable the further I mount the CARTRIDGE Ground leads towards the socket… The nearer they get to the power GND returns, the louder the hum…
The hum seems to get quieter if you touch the case… This happens whether I common MAINS EARTH with the STAR GND in the PSU or not – this doesn’t make a difference, nor does it make a difference whether the 1u case is connected to the GND bar…
I’ve tried about 10 different GND distribution schemes so far, but I keep coming back to the classic STAR config, with everything returning to the bar. If I return the Cart GND (via an unused lead in PSU cable) to the PSU’s STAR point (cap centre point + CT), it gets much noisier… The cart seems to prefer getting a GND away from the rest of the pack. I’ve made many phono preamps over the years, but I’ve never had trouble such as this…
The hum is the same whether a turntable is connected, or whether I insert shorting plugs. Hum forms a perfect sine on ‘scope. Hum gets worst as I approach preamp and less when I touch it. I’ve tried turning off all lighting etc in workshop – no difference.
The preamp compares favourably to commercial units I have, but I am very worried it could misbehave out on the road in EMI-hostile environments… The inductive hum that gets louder as you approach the 1u case is very odd… If you’re across the room, the hum is virtually inaudible – below the hiss floor – it only gets loud if you stand by preamp, and quieter if you touch it…
Any comments gratefully received.
Justin
Justin
