Adky
WHat is a Tube Saturator anyway?
« on: May 22, 2007, 12:15:50 AM »
I am thinking about building some kind of line level preamp buffer to add some tone or color to audio tracks that are too sharp and or thin , and I got one of those Behringer MAGICIAN dig out , and I dont see anything worth useing it , it sound rather too Low fi or too Cracking ... might rather build something that actually works , anybody got any idea about How or what a  TUBE Saturator should be?
Thanks in advance!
josh
« Reply #1 on: May 22, 2007, 07:46:01 AM »
Saturation is a characteristic of tape that IMO has become the latest "magic button" solution of the DAW world's clarity.  Without a tape machine, anything you build will just be an approximation of that, and arguments abound whether or not it sounds "right".
Too thin?  Run it through a Neve preamp clone or similar.  Something "big"
Too harsh?  Experiment with filter curves that tone this down without taking the body away.  Almost every eq spectrum I have ever seen out of an analog  box has started rolling off at 10k-12k or so.
Too Lo-fi?  Re-record.  I dunno what other peoples definition of lofi is anyway.  I think of bitcrushing & LPF'ing when I hear that word, and this is a very specific effect to be sure.
You don't need saturation.  It's just a pot of gold at the end of the rainbow anyway.  Build yourself a couple transformer based compressors and preamps, and start routing your ITB sounds out through them and re-record them.  Selectively, of course.  Many sounds benefit from the clarity and focus of a digital environment.  You'll get the character/color you are looking for this way.
If not, go another step and build the sumthing box.
Josh
Godders
« Reply #2 on: May 22, 2007, 08:24:32 AM »
Or just track it so it sounds good to start with. (old fashioned I know  :green: ).
Nick
Adky
« Reply #3 on: May 22, 2007, 12:41:17 PM »
I am actually thinking about building a BOX with a Variable BIAS so that I can alterate the tube operating point to get a different feeling or have different voltage selector or even put in couple different input transformer for some iron tone that I can select with ....
Planing to use a 12AX7 or 5670 or 5814 or 6DJ8 to do the gain stage ...
anyone have anymore idea?
Is more like a TONE box that I am building in mind ...
thanks again
Flundran
« Reply #4 on: May 22, 2007, 01:42:10 PM »
Another thread on this subject, with some ideas:
http://www.groupdiy.com/index.php?topic=16525&highlight=distortion+tube
Kingston
« Reply #5 on: May 22, 2007, 03:45:38 PM »
another course of action might be to make a NYD one-bottle with switchable feedback and non-feedback gain staging. I've been looking into doing this as the next project of mine. non-feedback version would provide the tubey sound (with lots of dirty gain), and feedback loop the clean version.
I didn't check on the feasibility of making the actual switch yet, and just how possible it even is.
hejsan
« Reply #6 on: May 22, 2007, 07:08:02 PM »
Quote from: "Kingston"
I have been thinking of the same thing, but my first impression was that it would need a lot of switching.  Have you come up with a solution?
cheers,
hejsan
Just remember -- if the world didn't suck, we would all fall off.
Quote from: "Butterylicious"
Adky
« Reply #7 on: May 22, 2007, 11:04:14 PM »
well...I am thinking about making it like a Line Amp stage thing... with variable Bias and saturations point...I dont know yet...and then will add in the ability to have it overload and filament votage switching , also will try to have overdrive capability and then I will add a DRY and WET balance point to have it dial in..... maybe I will put it on paper to see will that work or not .... still doing a lot of research so far...or might be just totally useless after all ... :cool:
bernbrue
« Reply #8 on: May 23, 2007, 08:29:53 AM »
to get tube saturation or colour a kind of tube summing box would be a nice solution. Have a look at this one:
http://www.tegeler-audio-manufaktur.com/tube_summing_mixer
regards
Bernd
hejsan
« Reply #9 on: May 23, 2007, 12:56:03 PM »
Quote from: "bernbrue"
regards
Bernd
I don't think I'd want much distortion in my summing network of all places.
Not that it's given that a tube summer has any distortion..
Adky
« Reply #10 on: May 23, 2007, 01:19:26 PM »
by what means , I will just need to build a TUBE mix buss gain stage with Transformer output and input , and a BUNCH of 10K resistor to do the individule input ...
or I can have indiv input gain stage and then add in the final mix buzz
if then I will have a single 6J1P at the channel input and then maybe a 12AU7  or even a 6SN7 or 5670 at the mix buss output , and I can even make it unbalance too or have the SSM balance chips to do the balance work instead of big hugh iron... hope this will fit into a 4U box ...maybe add a electronic input relay switching at the master output ... or 1 12AX7 to do 2 input channel and then  finally go to 6SN7 master gain block...that way I can use less tube in it....when I got some time next week I will draw something up...anybody got some good idea? anything will help or am I just over thinking, and should drop the project instead....hope it dont blow up ...haha
Kingston
« Reply #11 on: May 23, 2007, 05:40:13 PM »
Quote from: "hejsan"
cheers,
hejsan
I just had another look at it and I think I came up with an interesting solution, which must look like a nasty hack to the old timers here. Instead of doing a switch, one could simply wire the feedback and non-feedback parts of the circuit at the same time, effectively creating a sort of a mixer for the two types of gain. You'd have two gain knobs (one linear for the feedback, log for the non-feedback).
I'm looking at the schematics and thinking, why not? It's even cheaper than a switch, and even more flexible. If anything, it should be an interesting practical test and I have a feeling it would result in a very flexible preamp.
hejsan
« Reply #12 on: May 23, 2007, 09:38:02 PM »
Do you mean having to gain stages who's output you mix?
Kingston
« Reply #13 on: May 24, 2007, 02:25:19 AM »
no. using the exact same one gain stage, but wired as feedback and non-feedback at the same time.
have a look at the schematics and you'll see it requires two different gain potentiometers (log and linear) and their corresponding wiring set up parts. Besides that it's still just a single one-bottle preamp channel.
Tape Saturator?
Started by ebartlet « 1 2 3 » The Lab
Last post December 03, 2004, 12:35:59 PM
by magicchord
Last post March 13, 2006, 03:23:15 AM
by Purusha
Last post January 16, 2010, 03:30:08 AM
by superslaukey
Last post December 08, 2010, 06:47:55 AM
by simonsez
