Are you using MPSA18s and that is reason why all of the transistors are backwards. Also, you don't have the jumper connected. This has to be installed unless you are using potentiometer for trim.
Paul
Yep, MPSA18s I happened to have on hand already.
And I did have the jumpers connected when testing. The pictures I posted were of the 3rd of 3 boards I attached to test and I took the pictures before I put the jumper in. I edited my original post to say that but it's kind of an easily missed footnote.
I've since replaced just about everything and measured all the resistor values for accuracy and still no dice.
Thanks for taking a look.
