kdawg
la2a twist lock capacitor?
« on: June 11, 2007, 02:47:06 AM »
Does anyone know where to get the replacement 40/40/30/30 450V can cap for an LA2A? I need to replace one on an original unit, I'd rather not try to fit individual caps inside. I ordered a CE replacement can from tubesandmore.com, but ordered a 30/30/30/10 by accident and found out they don't have the right one. Closest I can get is 40/40/20/20 at 525V or 40/40/40/40 at 350V.
I was going to call up kulka's studio electronics tomorrow. Can they be ordered anywhere else?
-kdawg
Vetsen
"The smoke from the flux is filling my lungs..."
SSLtech
« Reply #2 on: June 11, 2007, 11:21:27 AM »
S'not a twist-lock by the way.
And he said that he'd already ordered one from tubesandmore...
"A waist is a terrible thing to mind"
Quote from: PRR
Ah, but that was 1999; we don't party like that any more.
drpat
la2a twist lock capacitor? New
« Reply #3 on: June 11, 2007, 12:07:30 PM »
« Last Edit: September 17, 2010, 09:51:42 AM by drpat »
I use the LA2a on very hot signals like lead vocal.
CJ
« Reply #4 on: June 12, 2007, 03:00:08 PM »
If you don't care about antique rersale vsalue, convert it over to regular caps, if you can find the space.
The only ones I would buy would be new reissues.
You will find NOS, but they may be hit and miss if they are from the 60's.
You can go over voltage, 525 is safer, and the new caps tale up less space, so hum will not be an issue.
that thing is over filtered in ther first place.
the guy probably pulled an old tv set cap to proto that comp in a glovebox.
Frank's Tube Page: www.mif.pg.gda.pl/homepages/frank/vs.html
Guitar Amps: http://bmamps.com/Tech_sch.html
drpat
« Reply #5 on: June 12, 2007, 05:11:51 PM »
« Last Edit: September 17, 2010, 09:51:53 AM by drpat »
cannikin
« Reply #6 on: June 12, 2007, 07:15:33 PM »
Here: http://www.vibroworld.com/parts/tech15.html
Bottom of page:
40/40/30/30 mfd @ 475vdc   4-section chrome Can, Twist-Prong FP type. Fits UREI LA-2A, Magnatone M7, M15, 440 amps
Tube limiters..yum!
Last post November 04, 2008, 08:41:30 PM
by amorris
Canada Post lock out
Started by Rybow « 1 2 » Brewery
Last post July 06, 2011, 11:24:45 AM
by Rybow
Last post September 14, 2011, 03:18:45 PM
by gemini86
Last post March 07, 2013, 05:57:34 AM
by tv
