Telefunken V672D Oscillating
rodabod
London
Hi guys,
I'm having problems with oscillation on a Telefunken V672D preamp (used as a mic preamp).
There are a pair in a rack, and the second channel has recently started "motorboating" (thud...thud...thud...thud...).
The electrolytics are all original. Should I start by replacing these as they will surely be dry now, or are there any other known problem areas where I should look?
The racking job is fairly impeccable, and the general wiring, etc. looks good to me.
Roddy
A while ago I bought four TAB V372D. I don't know how similar they are, but there were a lot of broken electrolytics in the PSU part. Some broken transistors, too, probably as a result of dead electrolytics surrounding them. So it's probably a good idea to replace at least the electrolytics in the PSU section.
Well, I replaced all the red electrolytics as Silent:Arts suggested in this thread:
http://www.groupdiy.com/index.php?topic=14037&highlight=v672d
But it is still oscillating. Maybe I should replace the old Frako electrolytics too.
Ok, that's all the old electrolytics replaced and it is still oscillating sadly.
Any other ideas?
Hah! I replaced the only cap which was newer (it had been replaced already) and.... Voila! It works fine now.
Lucky I tried that.
Cheers, Rossi.
Roddy
:thumb: :grin:
Those electrolytics, I tell ya!
BTW. When I got my V372D units, I anticipated that the tantal caps in there had gone bad (lots of them in there), but they were fine, actually. I replaced lots of aluminum electrolytics of various brands, a few transistors and even a trim pot, but not one of those tantal caps had gone bad.
