Sleeper
Hi Rob, I'm having the same problem with the anderton circuit and a sansui reverb... don't know the make on this tank.
I also built an lm386 amplifier onto the board either which should drive a lot more than this tank. doesn't though.
I'm tapping off of the anderton circuit with the 386.
If I unclip the tank, both amps are ok.
I wish I knew how to test out the tanks. I have impedence on mine
I put this aside, but I was also going to investigate the mix circuit on the anderton, when I was injecting signal around I don't see that the return is working correctly but I used the board design from guitargadgets.com.
If you want to trouble shoot this together PM me.
Kelly
Kelly
