Like clintrubber asked earlier, what do you want to use this for ? You mention alignment, what do you need to align ?
JDB.
Keithley 776 freq counter
and check my Tek CFG280 funct. gen.
Any idea on the accuracy you need ? 1% ? 0.1% ? 10ppm ? <1ppm ?
The Keithley counter has 9 digit resolution :shock: I don't haven't received the unit yet, but the ebay seller could not get a correct reading. The 10MHz reference output on the rear, when connected to the front input, gave this reading:
http://www.bpai.us/min/KEITHLEY_776-3.jpg(It's possible he does not have it setup correctly. There is also an internal jumper, designating weather or not to use it's internal 10MHz, or an external 10MHz reference.
Do you care about jitter / phase noise ?
should I ? XTAL/TCXO's and HF are new territory for me.
WWV transmits on 10 MHz so get a shortwave receiver and tune to 10 mHz............
.......... Turn on your osc and you should hear a beat frequency. You can look at the beat freq and measure how accurate your osc is.
I have a cheap one, a "Realistic DX-150A" with a 100 foot wire stretched accross my yard.
...but I also have a beautiful big'old Philco "frequency selective voltmeter" that I've never used...I' haven't messed with it yet. I have the manual.
The time transmission from the NTSI is on multiples of 5MHz......... You need a shortwave receiver to listen to the heterodyne between the primary standard frequency and your local oscillator. You may need to attenuate your local oscillator output in order to do this, depending on how close you are to Boulder. You adjust your local oscillator to minimize the beat.
"minimizing the beat"....is this like a canceling-out routine....if they are in sync, they cancel each other? (or "step on" each other?)
Thanks for your replies.
your willing student,
=FB=
