jpmtv
Re: Neumann TLM circuits
« Reply #20 on: January 26, 2018, 11:37:44 AM »
I'm new in this fotum and I'm french, so sorry mor my English !
I'm looking for the schematic diagram for a Neumann TLM103.
The link in this topic doesn't work anymore.
Is anyone can help me ?
Thanks a lot
« Reply #21 on: January 26, 2018, 12:14:23 PM »
Yes!  Back from the dead.
I sent Gus a bunch of pictures of the TLM67 circuit boards, but I've no idea how much luck he'll have with photos of SMD layout.
opacheco
« Reply #22 on: January 26, 2018, 12:18:15 PM »
I have searched that schematic long time ago and I have found nothing about!!....if somebody can help me will be a great gift for me and us in this intense searching process!
Why is so difficult to get this schematic??
Opacheco.
I love the Vaccum Tubes Sound!!!
« Reply #23 on: January 26, 2018, 01:01:46 PM »
Because Neumann doesn't fix these, they swap the entire board.  Thus, no one needs it from a service standpoint.
opacheco
« Reply #24 on: January 26, 2018, 06:10:50 PM »
But they must have a schematic for!!....and someone must have it, the question is who??
radardoug
« Reply #25 on: January 27, 2018, 12:18:11 AM »
Neumann will have it, but why should they just give it to you?
They will have spent a long time developing it, maybe there are proprietary parts to the schematic.
How much are you prepared to pay them for this info?
RuudNL
« Reply #26 on: January 27, 2018, 05:23:10 AM »
I got the impression that Gus (the first post in this topic) once tried to trace the TLM103 circuit?
Maybe he can help. I know he is an expert in reverse engineering!
There is a solution for every problem!
http://www.vansteenisaudio.nl
Gus
« Reply #27 on: January 28, 2018, 10:42:10 AM »
Tracing the the 103 is not going to happen. I lent my 103  years ago and is has not been returned.
I gave up on the 67 trace from pictures. It has epoxy on some parts
If people want to trace this circuit two ways to try come to  mind
One apply a signal to the amp boards and measure the output frequency response and maybe even distortion then design a circuit to fit that.
Two remove the epoxy and trace and measure all the parts this could be be destructive and you could be left with a non working board.
Now if you want a solid state 67 circuit do what I have done.
Design a 120VDC powered solid state M269 like microphone.
I have built a 120VDC solid state 47 inspired microphone with a solid state gain section.  One of the next things  to build will be solid state M49c like circuit and solid state M269 circuit.
« Last Edit: February 05, 2018, 05:48:41 AM by Gus »
gyraf
« Reply #28 on: February 05, 2018, 03:01:52 AM »
Came across this at some time - it may form the basis of someone's reverseengineering?
Absolutely no idea about accuracy...
Jakob E.
« Last Edit: February 05, 2018, 06:01:26 AM by gyraf »
RuudNL
« Reply #29 on: February 05, 2018, 05:40:13 AM »
Interesting! Just an observation: the combination C4 (10uF)/R12 (1K) looks at bit low to me. (LF loss?)
abbey road d enfer
« Reply #30 on: February 05, 2018, 01:28:53 PM »
-1dB at 30Hz, who's gonna notice?  :)
opacheco
« Reply #31 on: February 05, 2018, 03:46:54 PM »
Jakob E.
gyraf,
Thanks a lot for share with us your file!!
I will need to check it with my TLM103 now!...I let you know when I got it.
Opacheco.
bockaudio
« Reply #32 on: March 31, 2021, 05:18:04 PM »
The two output caps on mine are marked 47uf 50V.
  AKG, mackie,neumann,rode and ? use this type of balanced drive.
Certainly the output caps on my tlm170 weren't great, changing them was monumental (sonically).
opacheco
« Reply #33 on: April 01, 2021, 10:53:25 PM »
bockaudio, what kind of caps did you use (type, brand and values)?
opacheco
Last post July 28, 2005, 09:37:06 AM
by Gus
Last post May 05, 2009, 08:24:19 AM
by hotbaby
Last post October 02, 2019, 01:59:39 PM
by IndietownRecording
Last post April 04, 2021, 08:51:33 PM
by JRE Productions
