I've had these done for a while now, but realized that I never posted my end result.
I was able to mount all four channels inside a quad Purusha case by building an external power supply.
The unlabeled switch, changes the meter to read one channel at a time. I didn't have room for separate meters.
The meter holes were drilled hella crooked, but I calibrated it to my Pro Tools meters so that I could adjust it remotely without straining my eyes...
The first two channels have Profile output transformers. The last two channels use the CJ home spun output transformers. All four channels have Sowter input trannys.
I used one pico meter board to handle the metering for all four channels.
These relay boards handle all of the polarity, pad and phantom switching at the XLR connectors.
Power supply is +/-18V w/ 48V phantom made with Keith's power supply board. I picked up a NOS 3A power transformer at a local electronic store for $5, so the power supply is really heavy, but I have enough juice to easily power another Quad SSL9K box. That's why I mounted an extra 4pin connector.
