martthie_08
There is a nice pair of old Altec 438c tube compressors sitting on my bench. I'd like to show some of the crimes I have committed :grin: and ask for a bit of advice. First a pic with clothes on:
The units are in decent shape and there has been some work done on these by the studio tech before I got my hands on these (added an attack pot). Still there are some issues which I started to work on, after reading all the great information here provided by NewYorkDave and others. :thumb:
In agreement with the owner we decided to ditch the mic preamp section, which gave me a chance to add an input pad to replace the volume pot on the front. These units have tons of gain, even on the line input, so the pad is a stepped U-pad with 3dB steps going from -12dB to -27dB. In addition to that I built a little "outboard" output pad which is a 600 ohm bridged-T pad with 0dB / -6dB / -12dB / -18dB. This gives good control over the levels.
Next the worn out selenium rectifier was replaced with two 1N4007 diodes. This knocked up the voltages a bit, maybe by 10% or so, which I presume should still be ok.
The PSU filter caps will be replaced, I just got the replacent caps in the mail today.
I'd like to add a three pronged American mains connector, but they're hard to find in Germany, if somebody knows a place that carries them let me know!
still to do: check out the attack and release times, recap the signal path caps and add a meter adjustment pot.
I'd also like to add a balance control to the 6BC8 variable-gain stage, as suggested by NYD - is it best to use a mulit-turn pot for this? How many Watts does it need to handle?
Last question: Can I use the mic input transformer for the one-bottle-preamp? :grin: It is a type K308D, I couldn't find any specs on this though...
I'll post further progress of this project, I'd be happy for any suggestions!
cheers, Marten
cheers, Marten
