U47 fet pics
Kid Squid
Port Toilet, South Wales
Hiya Chaps,
just checked over a 47fet for a mate - no signal !, and diagphram was a 'little bit' dirty :wink:
traced problem down to the O/P pad switch ( cleaned up, and reset the contacts) working o.k. Also the output connections, were a little bit ropey !
While I was in there, cleaned up the capsule , as per previous posts
http://www.groupdiy.com/index.php?topic=697
http://www.groupdiy.com/index.php?topic=22287&highlight=u87+capsule+cleaning
anyway, here's the pics - bigger res at http://www.twin-x.com/groupdiy/thumbnails.php?album=172
Steve :thumb:
cheers - very nice pictures!
you can see the secondary (low-z) side as the inner (fatter wire) layer, the feebackwinding in between and the secondary on the outside.
http://www.twin-x.com/groupdiy/albums/userpics/IMG_3391.JPG
No worries Charlie, :grin:
Max, I'm glad they were O.K., are you going to be making you own soon :wink: Let me know, as I'd love to have a go at doing my own 47 fet !
On another note - my G7's are nearly done, a sneak pic for you
Steve :thumb:
wow - looking forward to see the finished mic very nice work so far!
what capsule, tube, transformer?
i´m collecting data of different mic-out transformers, i started winding some variations with different coil structures which accomodates the impedances of the ef 86 & ef 12 in triode mode - pics of some experiments can be seen in the dissection thread.
-max
Nice one Max,
I'm using a Peluso capsule - can't remember the model, but it's the dual capsule.
For the valve, i'm using a pair of n.o.s. Telefunken EF86's, and at the moment, I'm using a Lundahl 1538, but I'm going to try the 1538XL out as well. ( Got to finish of the wiring tho :shock: )
I'd be well up for testing some of your transformers, if you ever need some extra hands :wink:
I'm at the start of a very big hill with regard to transformer winding, but I'm starting to get my head around it a bit more, where have you been getting your supplies from ?
Also, just remembering, there's some telfunken transformer data around here somewhere. can't seem to find the post tho.
Steve :thumb:
hey Steve, I have a G7 with a Peluso capsule and NOS EF86. I did vocal tracking this weekend through a DIY 1272 > DIY LA-2A.
Fantastic results, honestly. I've recorded this particular singer several times. I've always had some troubles softening the midrange in his voice. This combination worked great.
