[quote author="Purusha"]It's not easy to make them perfect, I know. This was the best I could pull out of the sound. I'll try impulses next time.
I plan to build an ISO BOX aka Randall but also with 6" speaker inside. This is a very good trick I heard somewhere.
You don't need to run it loud at all and there is plenty off bass. I will record it in parallel with Motherload and you can
also lower the level going to the speaker with Motherload and have the amp cranked up. Will see how it goes next time.[/quote]
Or, just use a couple of great amps with 4x12's miked up in a real room. :grin:
