Build your own CNC machine.
Sender
USA
http://www.instructables.com/id/EG9RXG6F54HJ7SL/?ALLSTEPS
Looks pretty cool, and very do able. I wonder it will have enough gumption to handle aluminum....
Also he doesn't get into how it's controlled. Would anyone know anything about that?
I think it will handle just what he says: "Foam, plastic, wood and other soft materials". I know my mill really strains when its doing deep cuts in aluminum and it has a 1HP motor. There is a lot of vibration at the beginning of the cut as the cutter tries to drill down vertically. Aluminum is a pain to mill unless you use a cutter with four flutes and very high spindle speeds. Otherwise it just galls and the stepping motors snap the expensive cutter in half.
I posted links to all my parts and software suppliers in this thread:
http://www.groupdiy.com/index.php?topic=22962&highlight=
