valvehead
Active member
Here's a project that I finished recently. I got tired of turning on the light every time I wanted to pull out a record to listen to. I built this system of LED clusters to suspend over my records. Each cluster has three white LEDs with a 60 degree spread. They are powered by an LM317T. I scaled the adjustable voltage to give a current range in the LEDs of about 100uA to 18mA. There is a separate on/off switch for the lights so that I don't have to turn the whole PSU on or off. I even put a 470uF cap across the adjust pin so that the LEDs fade in and out slowly. I chose to use electrical boxes and conduit not only because they are cheap, but I happen to enjoy the industrial look.
pic1
pic2
pic3
pic4
pic5
pic6
I'm going to put another set above the next shelf where my 7"s and cassettes reside. I also have single LED suspended over the record player so that I can see the grooves.
I just noticed that in pic5 you can just barely see two MX5050s being used as the base for my coffee table :grin:
pic1
pic2
pic3
pic4
pic5
pic6
