Rogy
Maselec 9001 Keith?
« on: August 27, 2007, 01:01:57 PM »
Hi all,
I just got a pair of maselec 9001 EQ cards for SSL 4K off evilbay.
I would like to rack them up, so here are a couple of questions:
Does the card use the same pots (same values and taper) that were standard in the 4K for frequency, Q and level?
Anyone has the pinouts for the edge connector?
Of course the schematic would be too cool, who knows...
Thanks in advance!
Greetz,
Rogy
SSLtech
Maselec 9001 Keith?
« Reply #1 on: August 27, 2007, 02:39:39 PM »
Yep. They plug right in.
There should also be sockets in there for G-series versions...
Leif hasn't shared the schematic, so you won't have any luck there, but the standard SSL 82E02 edge connector pinout will work.
Did they have any others, or just the 2 that you got?
Keith
"A waist is a terrible thing to mind"
Quote from: PRR
Ah, but that was 1999; we don't party like that any more.
mata_haze
Re: Maselec 9001 Keith?
« Reply #2 on: March 28, 2012, 05:13:20 AM »
Hello,
sorry to bring up this topic again. are the 9001 cards ok to be plugged on an SSL E series dated 1982?
the console currently has a mixture of brown and orange EQs.
Mattia.
SSLtech
« Reply #3 on: March 29, 2012, 03:47:47 PM »
SHould be fine.
I assume the 611 module is marked SL611EK81 or something similar... either way, it should be fine as the 9001 is set as an 'E'
Quote from: PRR
mata_haze
« Reply #4 on: March 30, 2012, 05:45:15 AM »
great,thank you.
I am not where the console is so I can't check,
is the SL611EK81 the main channel board where all the daugheters are connected to ?
Mattia.
SSLtech
« Reply #5 on: March 30, 2012, 08:24:40 AM »
Yep.
SL611E is the board, revision level will be the letter, last two digits will be the year... so SL611EM83 is 'M' revision, 1983 design.
Anything that will accept an 82E02 should accept a 9001.
Quote from: PRR
mata_haze
« Reply #6 on: March 30, 2012, 09:10:21 AM »
thumbs up for this!
thank you,
Mattia.
Last post October 12, 2005, 10:46:13 AM
by syn
Last post December 07, 2010, 06:20:24 PM
by Gold
Last post March 26, 2012, 01:18:23 PM
by Morelius21
Last post May 08, 2019, 03:40:09 PM
by Gold
