G guavatone Well-known member Joined May 21, 2005 Messages 1,608 Location USA Aug 29, 2007 #1 What bad side effects would using a non-shorting switch in a mic pre attenuator based on Dave's schems? Basiically I want to use a non-shorting switch Ii have for these. Are there any tricks wiiith this?
J just.sounds Active member Joined Sep 27, 2005 Messages 42 Location Weesp NL Aug 30, 2007 #2 Problems with a non shorting switch is that they pop loudly when you change settings.
G guavatone Well-known member Joined May 21, 2005 Messages 1,608 Location USA Aug 30, 2007 #3 Thanks. That's whay I guessed. Is there any way to avoid that by putting caps across the swiitch?
rafafredd Well-known member Joined Jun 3, 2004 Messages 2,409 Location Rio, Brazil Aug 30, 2007 #4 There won´t be a problem in this aplication. Just use it. They´ll pop in a feedback-gain-control situation.
G guavatone Well-known member Joined May 21, 2005 Messages 1,608 Location USA Aug 30, 2007 #5 Thanks rafa. It didn't make sense to me that it would be out of control. Maybe some scratchiness liikke the Hot Rod?
