Stupid SSL Mixbuzz question
Israel
Hello to all!
I just curious.
Went into calculations...
As I know, dbx202c control port impedance is around 600R
and they have controll voltage constant of 20db/1v.
If refer to original SSL schem, posted on Jacob's website,
82e26 and 82e27, there's 4k7 resistors in series to control
ports of VCA's.
On GSSL, we actually have 2k1:120r to get 6.1 mv/db.
This messed up my thoughts!!! ;)))
I missed something there.
The question is:
How many volts to get 10 or 20 db of compression
in original SSL compressor there's
at the output of T1 opamp (lf351-right after time const. capacitor) referring to 82e27????
Thanx!
Are you familiar with the different versions of VCAs?
Some of them require 50mV/dB compression and some require 6mV/dB compression.
So if your calculation is 6.1mV/dB, then I would guess it was assumed to have 6mV/dB type VCA.
This is a good document that talks about the different versions and control voltages.
http://www.thatcorp.com/datashts/dn127.pdf
Hi Greg, I know all this stuff.
Guess, where the question came from? ;))
My purpose is is to get adequate and close as possible to original
SSL mixbuzz behavior.
And.....
PEOPLE!!!!!
Anyone can answer to this question??????
