i am using a digi 001 (unbalanced -10dbu outs) and am building an 8X2 Pm1000 to use with it for summing/eq.
My question is regarding what I should do as far as inputs on the pm1000? would it be best to make switchable inputs (mic and unbalanced line in) or should i just build some type of balancing box for the outputs of the 001?
is there any way I can just run the unbalanced out of the 001 into the mic input of the PM1K or will this cause problems?
