Neumann OA10 for something else?
Yann de Kéroullas
Active member
Hello there ,
I have a lot of neumann OA10 opamp in my material ( eq , cutting amplifier etc..).
Do somebody know a opam wich is 100 % compatible with the Neumann OA10 opamp ?
Thanks for your help
Yann
Really, man. These opamps are fantastic, and there are no electrolytic caps inside those. Just replace any caps on your boards where the OA10s are used, and you will have really good sounding units.
I agree. The OA10 is a great design and there should be no reason to replace it. There are two tantal electrolyts inside if I remember right but they are from supply rails to ground (not in the audio path).
