Sourcing low value 1% tol. Resistors?
guavatone
USA
I am trying to find a 5.6R to 6R resistor with 1% tolerance. I found 5% Koa's. Maybe I am slipping into obsessive audiophilio land.
i'm making an attenuator where the low setting of -41 is on the bottom and by the time it gets to the top of the 4 pole ladder that 5% is much less when you get to 237R, which is my least amount of attenuation R value on one side of a balanced T.
I hope this makes sense, I've been climbing ladders and crassing Tee's all eve.
BTW anyone use these folks:
http://www.precisionresistor.com/index.htm
I think they are the same as halco or some offshoot
you can just screen resistors til you find 5.6, but remember that the 1 percenters usually have a beytter temp coef, but that does not really matter, unless you are going to build a studio on the dark side of the moon, which was not their best album, their best was meddle, but most commmercially headed follow the sheep types do not realize this.
they probably bought thriller, too.
what was the qwuestion?
Yeah, meddle is up there on my list as well as Final Cut. Don't worry CJ, Have a Cigar.....
